2x3, GUI?
After asking questions here a few months ago I finally got a 260 and, with the help of these great forums, I'm learning to set it up.
I'm trying to use the GUI to configure 3 inputs with three outputs. I can't find a factory preset with a similar configuration to modify. The Config Wizard seems to modify whatever preset is loaded. Is there a way to start a new configuration from scratch with the GUI? If not, can I do it on the 260?
Input 1 > Main Mix
Input 2 > Fill Mix with Delay
Input 3 > Monitor Mix
Forgive me if I missed this in the FAQs. If it's there I'd appreciate a link.
R.C.
Missoula, MT
Input 1 > Main Mix
R.C.
Missoula, MT
But you can set up a ...
Main mix
Delay fills (as long as it is the same mix)
& monitor mix.
Using GUI.
Main mix from board into input A.
Monitor mix into input B
In config mode...
Unlink all modules
Input A (I'll assume tops and subs) 1x2 x-over (outputs 1&2)
also input A 1x1 filter for delay fills (assume more full range or also usimg same x-over point as mains) (output 3)
Input B 1x1 filter (output 4)
While in config mode, right click on modules and boxes to change.
If you haven't done the online tutorial, you should. It goes thruough a lot of this.
Is there a preset you think I should start with? I'm doing a pretty simple setup. No subs. All speakers are passive two ways with internal crossovers. Most of the presets are more complex than I need.
Roy
In the GUI, select a preset (any of them) and click the Config button to set up for your ap. Name the outputs... Mains, Fills, Delays, whatever. Name the preset "City Aud" or whatever and load it into the 260. It really is simple.
I am trying to run a pair of JBL MR825s with a Carvin HT450 amp for FOH and some CGM floor monitors with a Crown Powertech2 amp. Eventually I want to add a fill channel but these two will get me running.
Roy
Or, you want a dual mono setup
Try pressing the [config] button on the GUI and you will then be able to find all the hidden goodies...
Look at U1 config, that's essentially a dual mono setup...
Now in the GUI select [config ] right click on the P (PEQ) you get a dropdown box that allows you to select 9 band PEQ / 28 band GEQ...
If you see something that is linked and you want to unlink them, left click to highlight, right click gets dropdown menu select 'unlink'
To link, highlight one box with left click hold [ctrl] and left click to highlight the other box, then right click and select 'link'
in the config mode, left click to highlight the crossover box, right click and choose from the various crossover types.
When done press config again and "replace existing config?" [yes]
