Help please
I need to ask for some suggestions.....what settings would you use for my set-up...such as x-over points, etc...
I was also wondering if I should run the sub amp in stereo or bridged mono?
I have read a lot on here but I guess I'm not getting a lot of it.Any help would be very much appreciated.
Tops - 2 Behringer EUROLIVE B215A 400w 2 way
Subs - 2 Pyle PASW18 8ohm 1000w peak 500w rms
I Behringer ep2000w power amp
1 DBX PA
1 DBX PA
set up a 2X3 ( stereo tops and mono subs) use the wizard.. all custom
set up an HPF of 45hz BW18 for the subs
cross the tops and subs over @ 100hz LR 24 (sub HPF and tops LPF)
lower the LOW tone control on the 215's to 9 o'clock and the HF to 10-12 o'clock
If you haven't already read the start here thread:
viewforum.php?f=61
and the FAQ's;
viewforum.php?f=60
These are things (specific things) that will help you
PA... or PA+?Measurement mic ? or no?
