Pink noise
Hi
Is the pink noise generator on 260 equal on all bands between 20-20kHz or centered on specific freq.
So if I want to check the levels between each output at low levels is this the pink noise to use?
I'm not sure I understand the application you are asking about.
Or, can I use the pink in 260 to check when the amp is going in to clipping?
That takes the board / console out of the loop and will likely give a false sense of security. For your purpose, pink noise should be generated as an input to the entire system, not just the DR outputs and amps.
can give at least >+20 dBu 20-20k. I have one that only have pink noise that gives -14 dBFS at 1 kHz, but signal is not enough for subs.
Any tips for download a file with pink noise that will do the test for clip point for amps.
viewtopic.php?f=60&t=1202
This track has these power characteristics: Average RMS Power= -12.2dB. Max RMS Power= -8.77. Min RMS Power= -14.9dB. Peak Amplitude= -1.65dB
We Have a poster here that is getting some SR4732A's Would you chime in here:
viewtopic.php?f=29&t=2795
thanks
Gadget, what about the same rig??? :? But I can assist
