Program copy?
DraDra Posts: 3,777
edited March 2011 in PA General Discussion
Does the DRPA have a feature to copy an existing program and save it in a different slot?
I am using my DRPA as an inserted channel processor for lectern condenser mics. I have a dual PA set-up and have to do a "move the mics to the other end of the ballroom for the second part of the function" where the mics will go from a center stage position to a side of stage position. The only things that need to change will be AFS and GEQ. I will do the set-up during the initial set-up for the convention,
  • GadgetGadget Posts: 4,915
    If you want to save a program in 2 locations is...
    Press [store] answer the questions... one of which is "were would you like to store the preset?"
    enter the number location and [store]..
    But I have a feeling that's not what you mean...
  • DraDra Posts: 3,777
    That is exactly what I want to do. I just couldn't remember.
    Thanks G,
