JBL SRX718S Power recommendations with Driverack PA+
Hi guys, hope everyone is well!
I have recently bought a pair of JBL SRX718S subs to go with my existing JBL SRX725's. I already own the following equipment/amplifiers:
1x Crown XTi 1000
1x Crown XTi 4000
2x QSC RMX2450
1x QSC RMX 1450
DBX DriveRack PA+
I am currently bi-amping the SRX725's. XTi 1000 doing HF, QSC RMX 2450 doing mid per cab.
The QSC RMX 1450 is powering a pair of JBL Eon 1500 which I use as monitors. (Just replaced with some Turbosound Milan MI5 self powered) so amp is now spare.
I ideally want to power the above setup without having to buy another amplifier. I understand that the XTi 4000 probably underpowered for the subs and isnt generally brilliant for sub work. I had thought about bridging it and running both subs from that amp. As it will run 3200w at 4 ohms.
Can anybody advise on the above and suggest an alternative setup. Amplfiers are costing more and more over here in the UK!
Thanks in advance for your time.
1x Crown XTi 1000
1x Crown XTi 4000
2x QSC RMX2450
1x QSC RMX 1450
DBX DriveRack PA+
