Home dbx User Forum dbx Archive Threads DriveRack 200 Series 200 Series Configuration Wizard
DR260 + ITECH8000
rhyderhyde Posts: 10
Hi All,
I just hook up my DR 260 to an ITECH8000 amp I've purchased (driving a couple of SRX 728s cabinets).
I went through the wizard and it suggested all the default settings on the ITECH8000; okay, so far so good. However, at the end of the Wizard, when it would normally tell me to set the volume knob on some other amp to some value like 57%, there is.... nothing. Should I be setting the gain on the amp to 0dB or some other value? Not sure what should be done here.
Randy Hyde
  • DraDra Posts: 3,777
    The wizard says, "1-Set the attenuator to 0." "2-.......)
  • rhyderhyde Posts: 10
    Boy, I completely missed that.
    Randy Hyde
    What tha.... :shock:
  • GadgetGadget Posts: 4,915
    I deleted your duplicate post. It would be interesting (you do realize that the settings are already in the Crown amps) to see which sounds better, or if there is any difference... just make sure you don't use BOTH :mrgreen: ...
