Usage of Phase polarity.....?DRive rack 260
Hi
Thanks to all of you for your suggestions given on my last post. My system sounds better; but I only hear the lows when I stand between them(My setting is in Stereo). I would like to hear my system at 180 deg. Should I use the polarity Phase function? How to use it?
My system specs:
Mixer--Yamaha MG32/14FX
Crossover---Drive Rack 260
2 PV CS-800 series amps-(highs)
2 QsC PLX 3202--(mid)
2 QSC PLX 3402---(lows)
8 scoop bass speakers with EVX 18b Inside
4 top boxes (MID& HIGHS)
each box have 2 JBL 2206 12" speakers and a JbL 2447h High driver.
Thanks in Advance:
rol
My system specs:
Thanks in Advance:
rol
I mean facing them at a distance of about 50ft
My speakers are 25ft apart.
Have you verified that the speakers are all moving in the same direction at the same time? (absolute polarity) A 9 volt battery with the + battery terminal to the red/+ speaker terminal, and - to - should produce an outward cone motion.... (except certain JBL speakers that are reverse wound...)
you do realize each driver is only getting about 800 watts (on paper)
You need to verify the things above before we can help any further..
