Using mid out for monitors
I would like to use the DRPA to crossover tops/subs, as well as high pass and eq monitors. Can I run mid out to monitor, setup the high/low crossover as I normally would, and set the mid crossover points to high pass/ no low pass?
And it's all written up in a thread in the READ ME FIRST BEFORE POSTING section on the front page of this forum...
FAQ section:
viewtopic.php?f=60&t=2228
If you want to do this WITH All the benefits... you NEED to follow the thread... you can add to this the "Start here",
121.7 dB monitors and Auto Eq threads to get the most out of this setup.
Otherwise, your on your own here...
Author of said threads...
