Mid output jacks output a full range signal
Is it possible to make the Mid output jacks output a full range signal ? If so how is this set up?
Anyway...since the DRPX doesn't have a mid out and since you posted in the DRPA PX index... (see had to do WAY to much thinking on this already
Here is a thread in the FAQ section that might shed some light on the subject:
Oh and the answer is yes...
viewtopic.php?f=60&t=2228
Here I discuss how the DRPA can provide tops, subs and a monitor feed...
Is that what you needed?
Set up a 2x6 or a 1x6. to do this select "custom" speakers... Bi-amp... with custom subs.
Open up each filter (x-over HI, x-over MID) and adjust the frequencies to "full range".
The Mid and sub outputs have various HPF AND LPF filter slopes
To achieve "fullrange sound (which you DON"T WANT for monitors anyway...see below) you simply set the HPF (lowest point you want the speakers to go)and LPF (highest point you want the monitor speakers to go) where you want them.
Note: for monitors, you will have a MUCH easier time with stage volume and low end muddiness if you set the HPF @ 130hz (or even higher) and limit the LPF@ somewhere closer to 10-12Khz since a lot of that high end stuff is lost, and or not necessary..and can typically causes that high end squeal type feedback
It would therefore be better to run (2) (you will only get 2 mixes..) mixes off the mid and low outs... however, you get 3 PEQ's with the Highs that will allow you to high shelf the High outs and effectively add a pseudo LPF to the high outs...
Also, a PEQ set @ about 300hz will help with indoor howl and muddiness as well. I typically set a fairly broad Q (to cover 250 hz to 500 hz) (normally with more PEQ's a more specific cut, or cuts could be used, but in this case we have only 2 to work with)
As I indicated you will have only 2 mixes, if you have 3 monitors, 2 will share a mix..
