ZP 1261m with Davinci
I work for a school district that has 14 buildings each with a sound system in the dinning areas. I would like to be able to pull each system up from across the district and be able to make small minor adjustments across the network. Is it possible to use Biamp's Davinci software to program a front in to control all of these.
The files created in the daVinci software have to be loaded into an Audia or Nexia System and these units do not appear to be Third Party controllers.
In order to control ZonePRO units remotely, you would need to set up a VPN (Virtual Private Network) and access the devices using the ZonePRO Designer software or the other option would be to create custom remote panels using a Third Party Controller such as Crestron, AMX etc.
Jason Mondragon
dbx Technical Customer Service
Harman Signal Processing
