Compresssor/limiter/gate in front of DRPA+
Peter.GordonPeter.Gordon Posts: 14
edited July 2011 in PA General Discussion
G'day experts,
I've read on here that the compressor/limiter on the DRPA+ is not as good as the 260. Well, I have the DRPA+ and was thinking of putting a compresser/limiter/gate across the sub groups inserts of my A&H Zed 420 (1&2 desk output, 3&4 on vocals).
I'm not running the DRPA+ compression on FOH, but limiters set on overeasy 2 on both top and bottoms, tops at 8db, subs at 10db (after pinking and balancing the system) and nothing cliping (amps -3db from clipping after limiting). I pinked the system at -3db and nothing over 0db on the desk. With the DRPA+ peaking occassionly around -10db I'm getting volume complaints!
The object of the exercise is to protect the system from the odd Karaoke SCREAMER (limiter) who cuts loose out of the blue (karaoke mics on one sub channel and band vocalists on the second sub channel).
What are your thoughts on the best way of achieving this?
Cheers,
Peter
  • premier1premier1 Posts: 119
    In my humble opinion, just use the insert on your mixer for that particular vocal chanell, the DRPA Puts compression on everything , grab a dbx 266xl etc and use that on the inserts. Its not the compressor that isnt as good i THINK its the limiters in DRPA VS 260...The 260 has true brick wall limiters the drpa does not, anyway in my band i use the inserts for any compression needs and keep it off in the DR. I dont think you need a limiter on vocals, compression alone should be plenty
