hum developed ? any tips?
Ok here is the deal, when i run my subs aux fed there is a hum that has started to happen when the atenuator is fully turned up on my amp, once the band is playing its not heard obviously, I switched it back to running the subs from the drpa and no hum at all with the volume turned up, what could be going on here? I am feeding the subs from a subgroup out when i use aux fed, why is there a hum one way and not the other? do I need a di box between the amp and mixer to solve this? I just cant figure it out, thanks
I run mono FOH and Aux fed subs through the same DRPA+ every week, and even TRS out fm mixer to XLR in to DRPA+ I typically need to add at least 6-10dB of gain on the aux master to comp with the mains...
How is the HF projection at distance? Off axis response..is it spotty across the band ? OR pretty even out to say 30 or 45 degrees?
Since i aux feed my subs, during breaks I play music from the board and only those peaveys are working, they sound awesome! Im very happy as are my bandmates, these are well worth the money and they sound great right out of the box, peavey hit a homerun with these, hope this helps!
now back to the subs, I did notice I hqave to trun up the bandpass on the xti to get a good volume and with that comes the hum, cvutting 40hz and below help but its still there, and i wish i could use xlr but on the board the sux and subgroup outs are only 1/4 inch, i guess I can fool with the dsp more on the xti to try and rid them of most of the hum. thanks guys!
Are your amps on the same electrical circuit as the mixer/drpa?
What changed with your system that could have potentially caused a hum? Was any new equipment added? A new or different direct box for bass or keys? New gates, comps or anything else that inserts into your mixer (specifically unbalanced inserts)? Disconnect everything from the mixer except the aux fed sub. Does it still hum? If not, reconnect everything one piece at a time and check to see when hum returns.
Are there any ground pins broken off of extention cords or equipment power cables?
If you can run balanced aux fed subs, you could try lifting pin 1 on one end of the cable that runs from the mixer to the next stage in your chain (EQ, DriveRack, Amplifier. You can try lifting pin 1 between each stage if you have more than one). This, however does not address the cause of the original problem.
Dennis
