Peavey SP Series
hi, i use the DRPA+ for my Peavey SP2 for Tops and SP118 for my subs and the DRPA+ no had presets for that models. i use the RTA mic for setup the system but i think it sound better and powerful if i put some other parameters or eqs. for drive my system i use 2 crown XTi4000 in stereo for subs and Mids and a QSC GX5 for highs, all in stereo. it sounds clear and powerful but ithink it sounds better. i need more knowledge for work with PEQ, and the GEQ are set in flat. thanks for your help.
BUT.. fear not were here to set you on the path...
here:
viewtopic.php?f=61&t=959
is the "getting started" thread
here:
viewforum.php?f=60
are the FAQ's that target specific things....like:
viewtopic.php?f=60&t=2346
Where we pop the balloon that all you have to do is hook up a mic on a stand and run an auto Eq pass and presto....perfect sound...
or here:
viewtopic.php?f=60&t=953
where we discuss indoor Auto Eq...
Ok, so you say there isn't a preset:
viewtopic.php?f=60&t=1196
HELP... my speakers and amps aren't in the presets...what now?
Realistically...if your not bi-amping the speakers there will not be a preset, only a vague crossover point, and if the amps aren't in the list then the preset is most likely useless...
In your case your VERY under powered on the tops so you will want to hipass them around 100-120 hz with a steep slope like LR24...
So read up and see what you come up with...
