QSC K12's
Previously I had Mackie SRM 450's for FOH and a single Mackie SWA 1501 Sub. I have recently purchased QSC K12's for FOH and will not be using the Sub. I had run the crossover for my previous setup, and I am now wondering how to remove it from the mix. Are you able to turn off the crossover in the DRPA+, or is there a way to set it to full range?
Make another preset. (easy enough)
Lower the Low Pass Filter on the Hi output done to where you want it. (typically at or a bit below the -3 point on the speakers.
