DR260 to use with QSC K series active speakers
I'm not sure if there is another discussion thread on this topic. I own a DR260 which I would like to use with a pair of QSC KSubs and pair of K12's. I don't see these in the list of available speakers. How can I create a preset for the above speaker combo with DR260?
Are you using the GUI (Driveware)? Just select everything in the Wizard as "Custom". Then, simply set your x-overs appropriately. Do a gain structure. Listen and turn down the loudest component until then tops and subs are nicely balanced.
This thread is kind of a romp through the driverack setup...
viewtopic.php?f=61&t=959
Here is the FAQ section where we go in dept on any number of subjects:
viewforum.php?f=60
And here is a thread on the subject you started:
viewtopic.php?f=60&t=1196
If that doesn't answer the questions you have then fire away...
Simple questions...simple answers.
