OT : Flexible extention for Crown LM-300A podium mic
Posted on PSW... with no luck. So, bought it here.
http://www.samash.com/p/LM300A%20Goosen ... _-49995180
I fabricated a lecturn accessory (table top) to which 2 of these mics (their shock mounts) and a Lil'Lite are installed. It is portable and works very well.
However, I would really like to get the mic heads closer to the talkers(s). I engineered it so I can attach various length bolts to angle it as to move the heads closer.
This helps, but it is only practical to a point.
Does anyone know of an accessory that is essentially a goose neck, but has XLR connectors on each end? One end must fit into the shock mount. 5-8" long, I think.
It could also be a solid barrel, but it would have to have a pivot joint.
Last option, I suppose could be to simply insert a bar and clip into the mounts, but visually might look odd.
David
David
http://www.bhphotovideo.com/c/product/3 ... _Head.html
Side view. Not to scale.
There is adequate clearence for a typical note book binder.
......................................... x - would like go get here
................................x - typical mic head
_____
l
l
l
l
l_________________________________l
" | bolts with nylon caps
I deal with a lot of soft talkers. HA
