Mono/stereo question on the PX
when you use the two inputs on the DRPX and configure a setup of MONO are you really getting mono? or do you have to use only the one input marked L-MONO and one output and go out to one speaker and then daisy chain that to the second speaker? anotherwords when using both ins and both outs and then setting up a mono config, are you acually getting mono to both and how would it work if you only used the one in and one out and daisy chained? Just curious is all, THX
Probably. The stereo image comes with panning as long as there is two of something ie. guitar OR say for a vocal -- some type of time offset in the delay to create the image
Seems like you have a dual mono thing going on. As far as Daisy chaining goes -- you can do it completely on the mono as long as you don't add to many speakers and drop the ohm load too much. 4 ohm is pretty standard.
So if you have four -- 8 ohm speakers -- put two daisy chained on one input and two daisy chained on the other input. Basically Dual MONO
This works great as long as all of the speakers are the same model so the PEQ's AND Graphic EQ's settings will work well with all four.
Don't know if this answers your question or not. I run a mono setup for front of house. I only use ONE INPUT. The way I described above is the way I run my monitors.
If the DR is in Dual Mono mode -- then YES you are in Dual MONO. STEREO in the DR LINKS them together BUT if both sides are mono but Identical -- I am assuming they are since you can't really EQ one without the other -- then it is basically like Stereo. Panning at the console will demonstrate this with instruments that can be panned. Otherwise for vocals -- you won't even know it is stereo UNLESS you have an effects unit that offsets the delay to create the stereo image.
If you go MONO OUT and daisy chain -- that is fine as well BUT you won't be able to pan or use the delay to spread out the stereo image.
It isn't bad or not accepted to run the mains in stereo. Who said that? I have done both and I have concluded it doesn't matter a whole bunch unless you actually have material that is in stereo. Keyboards for example have nice stereo effects.
The debate on Stereo versus Mono is a long boring one that really relies on you to be centered at the acoustic crossover point of the two speaker stacks. Unfortunately, the majority of people are not going to be able to stand in the center at that position without overcrowding the area and again it depends on if the material being played by the musicians is even in stereo and requires panning...etc.
To me -- it is a debate that I am not emotionally attached too. At least for now...
If I were you -- I would just keep it in stereo -- change the DR to LINK the dual mono back together so it will be in stereo and you are done.
If you can't figure out how to do that -- I have a spare PX in my shop and I can fire it up and give you a step by step. You should be able to change it by going to the WIZARD and changing that specific part and then hit NEXT to get thru the rest of it BUT I don't remember for sure. I have accidentally erased some things before. Maybe you should copy the preset over to a new one first so you can always go back to the original IF your move to change the configuration backfires and erases your EQ settings.
What powered speakers do you have?
Use stereo. Make life simple.
DRA (Disclaimer: I don't own a PX, but I have been to a pharmacy.)
Subs too but if your are using the Aux -- you probably don't have a DR on them BUT instead on the tops.
Yeah -- there is a bunch of things you can do via the firewire returns and with Studio One. It is weird because you would think after all this time -- I would have tried it by now. Just busy with other stuff.
Hey G -- did an outdoor gig last night and the system was friggin amazing. Did you ever get my email on some DIY Coaxial monitors? Been seriously thinking about building some. The micro wedges got me thinking.
Ya.. summer is such a bitch for me to get ANYTHING done as I'm SO darn busy...
On an interesting side note.. the company I freelance for is doing ZZtop @ the Surf Ballroom in Iowa in October... I have all access ...should be interesting...
What got me going on the coaxial stuff is Dave Gunness at Fulcrum-Acoustics. There are coaxials in the Microwedge and I really dig the size. I am NOT diggin the $2,000 price tag though. I bet the P-Audio's in a DIY box -- Tuned up of course -would kick.
Have fun in Iowa -- sounds like a good time.
Check out Radian 5312 or 5312 NEO.....I believe the 5312 was the original coaxial in the Radian MicroWedge (before EAW)
Thanks Dennis! I sure will.
