dwd vs dwp files?
I'd like to use eaw dw* settings on the 260...Can I import .dwp settings into 260?
I see the devices allowed are *.dwd....
I'd like to use EAW KF300e settings....Is this possible?
Any help would be greatly appreciated
John
John
Once you have the file you will need to store it to some location for future retrieval, and that is as simple as clicking the store button on the GUI and naming the file.
gadget
.DWD (device) only tranfers the set-up: modules selected, cross-over config (including points, levels and filter types, but not sure about this???)
.DWP (preset) transfers that AND the actual "adjusted" settings such as GEQ, PEQ, Limiter, Gains, etc.
I see no practical use for the DWD myself, enlightened us, Gadget.
The process seems to work but the files I pulled over from dbxpro.com/speaker_tuning/eaw.php for KF300e
as *.dwp error with "bad format" when trying to import within dr260...
John
I did find generic processor settings for the KF300e here:
http://www.eaw.com/info/EAW/Processor_S ... S_rev2.pdf
Wouldn't be a big deal to manually load those into the 260.
Thanks for all your input and support.........Great Forum.....I am learning a lot
John
It's
goatroperdrummer@aol.com
John
The settings are as close as I could get, I didn't add the PEQ @ 20150hz... just not even audible for the most part.. if you want to, we can change the input GEQ to PEQ and you'll get 9 additional PEQ's per input channel, at the expense of auto EQ...
So for the tops only use you would want the 1-2 outs for the mid hi's and 3-4 outputs for the lows. The 5-6 outs would remain unused...
1. Open the GUI in the computer with the .dwp on it...click Ok to no connection...we don't care
2. click to run the GUI (insert the 260) then double click the 260 icon...
3. on the top blue bar of the GUI right click and select 'import program'
4. select the location using the "look in" tab at the top
5. find the program in the "NAME" box and highlight it
6. click 'open'
7 remember.. if you want to save it you will need to do so... if you don't you will loose it again when you close the program.
Could it be a 400 series file?
You could send me the file and I could see if I can find out what it is..
tzone42@paulbunyan.net
that's the best I can offer..
Thanks for the help
Dan
