Setting PX so that QSC Speakers don't get blown
I just started renting speakers for local gigs in the area. Many times I setup at these gigs and then have to leave to setup lighting equipment for another venue. My goal is to create a system that there is no way my speakers can be blown. I am not concerned about the audio quality. Most of these events are electronic music consisting of fast bass (genres of Dubstep, Happy Hard.core, drum and bass, and house music).
My Setup:
2 QSC KW153's for mains
2 QSC 1801 Subs
2 Mackie SRM450 V1's (Monitors, sometimes added as mains)
2 Mackie Thumps (Monitors)
and of course the DBX PX
What I have been doing, which is probably completly wrong, is setting the compression and limiter to ON and choosing OverEasy: 3. I set the Threshold to -20dB.
Any suggestions or alternatives? Like I said, I do not care about the sound quality, I just want to protect my equipment. I always tell the DJs that if they start redlining, the music is going to sound horrible. Do I need to buy the DR260 or is this still achievable with the PX? I am also currently reading the "Start Here".
Thanks!
-eighty8
My Setup:
2 QSC 1801 Subs
Thanks!
-eighty8
You need RMS protection a lot more than peak protection, though you need both. You could (and I repeat, could) get the RMS ratings of the components in the speakers, and add slow blow fuses at or just below those settings. There is a formula for figuring that.
Sqr root of ((P)ower/(R)esistence).
Horn:
Speaker RMS = 64w
Speaker = 16 ohms
64/16 = 4
sqr root of 4 = 2
Use a 2 amp slow blow fuse.
Positive amp lead ++++++[ fuse ]+++++ positive speaker terminal
Woofer:
Speaker RMS = 400w
Speaker ohms = 8
400/8 = 50
Sqr root of 50 = 7.07
Use a 7 amp slow blow fuse.
It is not real convenient to replace the fuses (you could add panel fuses), but is more convenient than recones.
You can do the same for peak wattage. Just use fast blow.
Breakers are also an option instead of slow blows. Yorkville used them for over a decade.
-eighty8
