Combining Horn and Front Loaded Subs
Hello,
I am working with Mark of BT Productions to help supply sound for a DJ show in Ohio. He is at work all day today so I thought I'd try and fill in the best I can to ask some questions that we had. We are planning on using his sound and setup: 2600, LA460, and horn loaded subs in addition to my QSC KW1801's because the promoter says that "there is not enough bass". Reading through previous posts I found a comment from Dennis that says front loaded subs and horned subs odviously do not work well together. Are there any software tweaks or DBX tweaks that we can run to match up the delays between the horn loaded subs and my QSC front loaded subs? We were planning to run all of his equipment through the 2600 and using my DBX PX to setup a matching delay to the QSCs as close as possible to his equipment just for this show. Also would additional subs cause noise or phase cancellation?
Eighty8
Dennis wrote:I believe LA400s are designed to sit up right. Horn loaded subs do not play well with front loaded subs even if you had a means of setting proper delay times. EAW processor settings for LA400 suggest mid/highs should be delayed 5-6 ms....I personally think that is a bit much. A while back, I time aligned an EV Elmininator over Cerwin Vega L36 with proper measuring equipment and came up with a 3.5ms delay time for the EVs (standard ballpark guess for the L36 is a 5ms difference).
Eighty8
I'll assume you meant 260 (not 2600) and that you will run a full range signal from one output of the 260 (delayed) in to the PX? (since the PX has no delay)
Hopefully Mark can sign on soon and fill in the gaps.
Eighty8
That being said I just picked up 4 old EAW SB850's that I'll get to testing tomorrow. I got those and a QSC Powerlight 6.0 PFC for $1600. One of the cabinets is for sure not going to work as the subs somehow got spraypainted and the surround is cracked on the one. None of the drivers are EAW and there is no crossovers or anything inside the boxes besides wiring straight to the drivers from the 8 or 4 pin connectors. I'm guessing best case scenario I'll get two working cabinets out of these maybe 3 if I'm lucky. If those end up working then obviously we should be better off and adding more front loaded subs is no problem. If not then idk back to trying to combine and hopes for the best or having a lack of sound
Thanks -Mark
You could let the LA400's handle the 30-55 hz and let the "lesser" low end speakers handle the 50-100hz area...
My Labsubs have a 10+ ms path length...and with propagation delay and all I use almost 15ms for them...
BTW the surround on the 18's in the 850s... if the speakers still move without rattling... can be patched temporarily with nylon and surround cement...I have had speakers last for some time with this method...so you want to run the 4 SB 850's on one QSC 6.0? 2 ohm load? You better have a BIG FAT line right up to a stout 240 volt power outlet...those will draw a whopping 30 amps or so @ 120 volts...or more!
Thanks -Mark
http://binkster.net/extras.shtml
You will need to play the frequency closest to the actual crossover frequency... say 100 hz. this will be played through the tops AND the LA400's. reverse the polarity of one of the speakers, tops or subs which ever is easier. (+ to + and - to - on one and the opposite on the other)
Play the tone @ medium to higher volume and sweep the delay on the driverack till you get the MOST null at that frequency (the sound gets the quietest.. it may not be an earthshaking difference but listen for the null) you have just found the point of most cancellation.. IE 2 frequencies arriving 180 degrees out of phase and cancelling each other out. (remember to correct the polarity reversal afterwards)
I'm curious... why not rent something for this one off rather then buy something you may not use afterwards? Seems to me that you could have found some more LA400's to rent, or buy.. and you would have then had a system that plays well together... :?
Those would seem to be Brazilian drivers...and it's not usually a good idea to just throw any speaker into a box... the box needs to be designed around the speaker...or you will get poor performance and overexcrusion is a real possibility...
-Mark
