DBX 2031 Connection
I have a question for anyone who wants to run some ideas by me. I run my PA in mono and the desk (Mackie 1604 VLZ PRO) has a mono output mix which is handy. I have a DBX 2031 graphic which is mono and in order to use it via insert, I have been connecting to the left insert only as I only have main insert left and right on the desk. This works well if I pan everything to the left. However, if I want to sub mix, I need to be able to pan the channels left and right which of course I cannot do right now. I had spoken to a Mackie tech about using splitter connectors in the back of the graphic so I can use left and right inserts on the desk. However, she told me this could overload the graphic. Without having to resort to putting the graphic between the desk and the crossover OR swapping the graphic for a stereo version - because I already own this one, does anyone have any ideas how I can keep the pans at noon ????? Thanks
what about main mixer out>EQ>Amp/speakers...(no need to insert)
just not quite sure what your trying to do?
The panning comment was regarding the sub-grouping available on the desk. It is a Mackie 1604 VLZ PRO. Subgroups are limited to channel 1-2 and 3-4. So I would normally pan 1 to left, 2 to right, 3 to left and 4 to right. SO if I have all my pans to the left using the left insert only, I would only be able to subgroup channels 1 and 3. This might be enough...just didn't want to reduce my options. Should have purchased a stereo graphic.........
BUT...line level signals are line level signals...I disagree that interconnection in ANY fashion can harm another stage.. power amps into line level signals .. no, but feeding line level signals to all the wrong places is a practice that I used to take great pleasure in...
BTW....I did use the eq in just the left insert using one insert cable with panning centered at first and adjusting the eq did not make much difference to the sound. A friend suggested I pan to the left and WOW..it made a big difference. Panning centrally was only sending a partial signal. Only then did I realize that I could now no longer use my panning on any channel if everything was already panned to the left.
Livesound mics and line sources> inputs> masters>(L) insert>dbx EQ>(L) main for live sound tops
I don't have enough Aux sends and I want to run Aux subs, can I run them off the the right output and use the pan control as the sub feed?
That is something I can understand.. I want to know what your trying to accomplish in the end, and why it's so important to have the EQ in the insert when if you maintain unity gain throughout the signal chain the meter reading will be accurate post eq... This requires that if you increase one band by 5dB you would need to average that with a 5dB cut OR an average of the EQ curve cut or (gawd forbid) boosted. There are lots of reasons to use XLR connectors instead of 1/4" type, and noise is the biggie..the signal strength is also nice...
As for the tech you talked to, what you WILL be doing is summing, and that may cause cancellations, but you won't HURT the EQ...line level signals are mostly below 3 volts... not enough to really hurt anything...
You are picking knits about the EQ affecting the metering on the mixer. That is what the input gain on the EQ is for. After adjusting the EQ, kill the amps or unplug the speakers, play pink noise, set the mixer to flicker +10, adjust the EQ's input gain to flicker it's meter +10. I chose +10 because it is the highest common indicator.
Gadget.. I Have run eq's both ways in the past - main out of desk to crossover and inserts. The insert on a desk is created for just this type of application among others so I am unsure as to why my reasoning is being questioned. All I wanted to know was whether my connections using the splitters would be safe and if so then I know my options as to where to place the eq. If not then same result..move forward using main out.
Properly summed these things are all possible, but inserting the EQ in a single sub, or master output is not the way I'd do it... the intent or purpose here just isn't clear.
