Major system issue... or set-up screw-up?
DraDra Posts: 3,777
I created a set-up and discovered a difference in the way the 260 thinks. Had me freeked out for a good bit.
Input 1 - A "1 x 1 mono filter" - Output 1 (FOH)
Input 2 - B "1 x 1 mono filter" - Output 2 (Monitors)
Monitor feed getting into the house mix.
Long story short... in this config you have to manually kill the opposite input in the master input section, else both inputs are summed into both channels. :oops: This is different than if you set up a 2 x 2 (stereo) filter and then simply un-link the modules for a mono FOH & single Monitor set-up.
  • GadgetGadget Posts: 4,915
    So your saying the input mixer wasn't "panned fully" 'A'.. and 'B'?
  • DraDra Posts: 3,777
    By default all 3 faders were at -0-. I suppose (now that I think about it) that it could have been that I did not do a Wixard set-up, just modified a factory preset. I bet that was the issue. :oops:
