Gain structure, threshold problems
Ok ran through the "start here" steps with the pink noise track. I am obviously doing something wrong. The pink noise signal coming from the mixer is just below peak but the th lights up red! So I turned down the gain on the lows and highs in the xover to we're the th barely lights up.....that puts the xover gain at -30!!!!! The meters on the lows and highs don't go above 20 and both my amps gains are turned all the way up and the signal is weak. What am I doing wrong!!!!!
Just to clarify a point here... we WANT the individual channels on the mixer to all have a goood strong signal, averaging at around -0- or above on an analog mixer, and good strength on a digital..(NEVER clipping) the main output faders on the mixer usually end up looking pretty low... sometimes even 30-40dB down.. or more.
It's more important (especially analog) to have a good signal to noise ratio, and with the majority of the gain in the channel stages that is also where your going to get the MOST noise injected...SO press the PFL button on each channel and that will give you the main meter as a guide for channel setup...
Are you using the "Start here" gain structure method?
