Optimum Setting (SRX725 SRX718S & DR260)
Hi,
I have Just purchased this system and primary usage for this system will be of DJ (not rental) by me only. Have been reading this forum recently trying to understand basics and been experimenting with DR260 but not able to get the optimum sound. Kindly help me out, I know its a bit of asking but really need proper settings as christmas & new year parties are just in the corner.
My Setup is :
JBL SRX 725 x 4
JBL SRX 718 x 4
QSC RMX 4050HD x 4
DBX DR 260 x1
I have tried the wizard but somehow its not working out perfectly, bass is getting shy. Where is the issue. Waiting for a positive response.
My Setup is :
JBL SRX 725 x 4
JBL SRX 718 x 4
QSC RMX 4050HD x 4
DBX DR 260 x1
P.S. In your reading did you see the "read me first before posting" sections?
Plz suggest.
You should probably have 4 SRX218's and 4, bridged 4050HD"s and 2, SRX 725's and 2 RMX2450's running bridged mono and an XLS602 for the horns...
That said, your stuck with about 850 watts for each of the subs... NOT enough to get them going by any means...
So, what do you want us to tell you other than that?
JBL provides all the specs for those speakers in "tunings" on the Pro website...
one side/
SRX718 - RMX 4050HD (Bridged Mono)
SRX725 - RMX 2450 (Bridged Mono)
XLS 602 (Horn)
same on other side.
For DR260 i should go with the wizard setting.
Yes bi-amping is definitely the way to get the most out of the SRX725's I believe the tunings for the 725/718 are available (there are 2 files, the SRX725BSUB and SRX725SBSUB under the 260 heading... available as a .dwp for import into the 260. They may be the same as the ones in the presets, but yes, those will get you the best optimization for the system (other than perhaps a tweak to the gain structure.. see the method in the "START HERE" thread for another way to dial in the system:
viewtopic.php?f=61&t=959
The Auto EQ optimization can also help you get a better sound, and all that is in the Start here, and FAQ sections.
Check the polarity of all your cables.
2x725 Biamped on one RMX4050 and the 602,
4X718 center clustered on two bridged RMX4050.
Configure your 260 from scratch with the wizard to get a tri amp system with mono subs.
Once this works, we can fine tune it but this system should work great already and if it doesn't then it will be much easier to locate the problem!!!
