Amplifiers....how big
ive read the Amplifiers....how big in the faq and am now more confused. i built the pa thinking i was doing well with the amps i got but now think i under powered my system. i want to get clarification before i start replacing my amps. my band uses the pa for practice and the small clubs without a in house system. we run vocals, kick drum, synths and electronic percussion through it(low end heavy sources...tr808). i have 2 B-52 mx15 for the mains. 8 ohm cabs rated at 300 watts. they are powered by a crown xls1500 rated at 300 watts @8 ohms per channel. subs are 2 B-52 mx18s. 8 ohm cabs rated at 550 watts. they are powered by a crown xls1000 run in bridged mono. 2 8 ohm cabs put a 4 ohm load on the amp, it is rated at 1100 watts @4 ohms bridged mono, which gives each sub 550 watts. the faq post says you should have 2-4 times the rated power on the speaker......so im way under powered according to this. i am thinking of buying another crown xls1000 and running each main cab on one xls1000 in bridged mono, that would give 700 watts @8 ohms in bridged mono going to each main cab. then buying a crown xls2000 for the subs, that would be 2100 watts @4 ohms bridged mono...so 1050 watts to each sub cab. should i replace the amps or is the way i have it ok/good enough?????
For Dj work, using heavily compressed music:
B-52 mx-15... rated 300/600/900 (RMS /program/peak) power needed = NO MORE THAN 600 watts
For Live sound, dynamic, rock music: Duty cycle of amps no more than 1/3 power)
B-52 mx15...rated 300/600/900 power needed = 600-900 watts per cab...
Live rock is MUCH more dynamic than canned music. Therefore you need more power to re-produce it. The problem with canned music is it's so heavily compressed the dynamics are happening all the time and so the duty cycle of the amps exceeds the max of 1/2 power (running more then 1/2 of the time) this heats up the voice coils and can destroy the speakers.... but the live sound business has no such limitation, and occasional peaks that exceed twice the program power are possible...
Now, if you hook up the system, and it does what you need, when you need it, your golden, your most likely not in any danger of burning your speakers if you don't clip the amps,
If, however, you run out of gas, can't get the sound you were looking for.. you don't have enough rig for the gig...
Now..the bad news... With B-52's CRAPPY spec sheet you have NO idea what 300 watts means... that could well be 150/300/900 watts (and very well could be) or 300/600/900...
600 watts isn't a lot for live sound tops, but then if your using TR808 samples they aren't like live drum sounds either... so perhaps were back to program value max again...only you can decide if you have enough rig... remember this, to get twice as loud as your 300 watts.. you would need 10 TIMES THE POWER... double the power will only elicit 3dB more sound...
Does that help?
30 hz????
Do you think that if the Peavey SP218 with it MASSIVE Low Rider drivers can only do 31hz @10dB down.. and are rated @ 49-300 hz that utilize a cabinet made of Baltic Birch...with a 600/1200/2400 watt rating...for a single driver...
If they can't hit those numbers with that setup... the B-52's with a 3.5" voice coil and a 550 watt rating under 100 lbs is probably made of MDF... that THIS is going to actually hit 30hz? That cabinet would fly apart at those frequencies..
It's called TRUTH IN ADVERTISING... or the LACK there of...It's all a game of numbers and half truths...To be honest, there are only a handfull of loudspeakers that can produce below 40 hz 3dBdown... and it usually takes a few of them to to even approach that number. 30 hz... that's a WHOLE lot harder to hit. ... and in groups of one? I can think of only a couple, and they are manufactured by Danley sound. One has 20, 15" woofers, and 20,000 watts of power built in... called the Matterhorn, another is the TH812, which has 8 12" drivers in one box.
Sure there are some home theater boxes, and I know Bill Fitzmaurice claims 30 hz on some of his stuff.. but they won't be able to put out 30hz in any kind of medium venue size place, or outdoors at all.... maybe a living room, or car or van...
Sorry to be the bearer of bad tidings... but they are OUTRIGHT lying about that spec... within any REASONABLE dB down figure. I bet those boxes are 10dB down @ 45hz...and are much more likely a 55 hz box...
gadget
Sorry to bust your bubble... but I just HATE the whole process of blowing the specs all out of proportion... I mean 30 hz... they KNOW that's a joke!
It is Christmas, so he may be hard to reach.
The B-52 are definitely marketed to DJ's. You may be able to sell them at a small-ish loss and do the upgrade sooner rather than later, since they are new. Did you buy them at a store? Maybe they will give you a good trade in.
