Input Headroom Meters are all but pegged in the red
after I go through the setup wizard and get to the RTA mic plug in and press next to begin it has the input headroom light almost all pegged to the top with little or no gain on the mic. What could cause this? I did the gain structure using our voices as we sing to keep each channel in the green instead of running pink noise through it, so what could be pegging the input lights?
1. Hook up the mic (Note, if the mic cable is BAD the auto EQ process will run WILD immediately upon starting the auto eq process)
2. You will be prompted to increase the pink noise level.
3. If you turn the level up till the input meters PEAK it will prompt you to TURN DOWN... If you want more level form the speakers you will need to INCREASE the distance from the mic...
I personally do not use this feature because it has a couple inherent problems... one, the crossover point and slope needs to be addressed... I almost never agree with what is there unless it's a setup provided for a bi-amp setup, like you would get with a setup from JBL for an SRX 738 or a 738 with subs... but then these setups DON"T need any auto balance because the crossover gains and amp sensitivity settings are provided anyway...
I would suggest that if you follow the 'START HERE' thread procedure for gain structure and setup:
viewtopic.php?f=61&t=959
The REASON they put in an auto balance feature is... that if you don't have the different elements pretty close volume wise, the auto eq process will boost or cut the levels to adjust for this imbalance.
There is also a lot of info in the 'FAQ' section under the 'Start Here' thread...
