Edit preset doesn't work
Hi All
I have an issue in that after i have created a preset i can't edit the main speaker levels from the PX
I can select any of the parameter blocks by pressing the appropiate buttons for example the EQ or compressor buttons
But the manual says that once I have a preset loaded and selected I should be able to hit the Next PG button and step through all of the presets parameters...but when i do this nothing happens at all
Is there someting I am not doing or is there a workaround
regards
keggles
regards
keggles
Do you mean the gains in the filter (x-over) section?
I am using jbl prx 625's without subs so I am not using the crossover feature at all
when you create a preset with the wizard the first parameter that comes up is the main speaker level
if you set this too low...like I did...because the rooms are generally really quiet when doing a setup
I just need to tweek that parameter a bit ...I know I can just push the mixer a bit more but I would rather be able to just edit PX so that when I come back to that room I have my levels all ready correct
Keggles
Sometimes you need to press the encoder, sometimes you need to turn the encoder, sometimes you need to press the [function] key...to navigate...
Try it... you cannot screw anything up by pressing EVERY button and knob...learn the Nav...
