Driverack PA+ & Peavey SP218 Subs
Hello all, there's no selection for the Peavey SP218 subs on the driverack pa+.
What would be the best selection for these subs during setup. thanks
The selection for the Peavey is WRONG anyway
"We don't need no stinkin presets..."
But your woefully short on information here...What tops.. and what amps? ...it matters...
I'll "Roll" you a setup, or you can read the "READ ME FIRST BEFORE POSTING"
viewtopic.php?f=60&t=1196
At any rate you will need to provide ALL the information to get the help you ask for...
the Peavey SP218 Subs i'll be running 2 crown XTI4002's in bridge/mono (1 sub for each amp).
Unless you WANT to sustain Damage to your speakers?
The tops look fine, but your a little long on power for the subs. I might suggest you incorporate the Limiter on the 4002's...
As for numbers,
Subs:
HPF 40hz BW18
LPF 100hz LR24
tops:
HPF 100hz LR24
Gadget69
2 Peavey SP 218BX PA Subwoofer
4 Behringer Eurolive B1520 Pro PA Speaker
2 Behringer EP4000 Stereo Power Amplifier
1 Behringer EP2000 Stereo Power Amplifier
Presonus 16.4.2
Live sound
LPF 100hz LR24
tops:
HPF 100hz LR24
Talking about these number?
