Home dbx User Forum dbx Archive Threads DriveRack PX
Graphic EQ to go along with PX. Redundant?
vandy79vandy79 Posts: 13
edited March 2012 in DriveRack PX
Would it be pointless to route a Graphic EQ in conjunction with a DRPX?
I was curious about feedback outbursts that might happen during a show that I could pull down faster with the EQ.
  • GadgetGadget Posts: 4,915
    It's often done where there are visiting engineers... note that not all GEQ's are created equal...
  • OklaPonyOklaPony Posts: 48
    vandy79, If this is in reference to your school cafetorium / gymnasium thing then I would say no, don't bother. The DRPX should handle feedback duties just fine.
  • DraDra Posts: 3,777
    If you have one it might be a good idea to have it present during set-up. It you see that you will need to make constant emergancy adjustment, then patch it in.
    In fact, if your mixer has channel inserts, use it for the most likely problem mics. That way you won't alter playback because some shmow (?) is a quiet talker won't get into the mic and you have to make that mic sound bad just to be able to hear them.
