Internal i-Tech HD processor or continue using my DR260?
I'm in the process of upgrading my system, I have one pair of JBL SRX725, one pair of JBL SRX728s and I need new lighter weight amps. I'm thinking if I should get the i-Tech HD 9000 + 12000 and use their built in DSP And a laptop with SA for processing or keep using the DR260 and buy the MAi series amps, also 9000 and 12000?
MA 12000i $3531.40
Itech 12000 i $4383.49
MA 9000i $2679
Itech $3530
A $1703 dollar difference!
I doubt there would be a lot of difference sonically, but there are a few more tools available in the driverack.. one more piece to carry.. but not that much...
Now, may I suggest an alternative? I think the best amps on the planet are the Powersoft/Digam amps. We have a couple of the older units, the Digam 5000 and 7000, simply the most powerful, and light amps available. We have run 6 LABsubs (3.2 ohm, dual 12" horn loaded) on one digam 5000 (on a 100' 14 gauge cable), and you could feel the bass 1/2 mile away! 1 rack space, 17 lbs, 1 rack space..AMAZING AMPS!
I would go with MAI and keep the 260 and be happy.
With both amps having RSM / averaging limiters, that really frees up the (any) driverack's limiter to be used more appropriately. With these 2 Crowns as choices I'd choose the MAI, take my wife to a nice restaurant.
Gadget, 1 rack space sounds sweet though.
For sub duty there isn't another amp on the planet that can match the the low end punch of these amps. The detail and total lack of power compression for both low and high can really bring out the sound in a quality system. Truly a thing of beauty on all accounts. The reviews that you'll find out there in the pro audio community you will hear of the utter disbelief at the power and quality of these amp.
Simply AMAZING... :shock:
These powersoft amps are not the cheapest you can find out there, about the same as the IT12000, I know they are great, almost devine, but I'm asking these questions to make kind of a feature comparison between the 260 and the internal DSP of the itech.
Gadget, where do you get these amp prices?
No the Powersoft are more than the Digam, and neither is cheap but I picked up the Digam 7000 for $1400 last year.
The place id Northern Sound and Light :
http://www.northernsound.net/?gclid=CNC ... DAod2mLoQQ
Those prices were just pulled up today so they are good for 30 days... you'll have to call for the price, but it will be the same..
Any way, I need new amps.
The Itech ones had so many problems I would never even consider buying new ones much less used ones...
What are the issues with them?
He won't touch a Crown now...Older MA's (we have a few that have been flawless) are fine, but as you know.. HEAVY :?
No company in the world can have a 50 percent failure rate for such an expensive product and stay in business, and even if it will stay in business, it will defiantly not have the reputation Crown has. To me, Crown has always provided super solid amps at all conditions and demands. A glitch here and there are acceptable as long as the company takes responsibility for it like they did in the ribbon cable fault on the older XTIs. I don't know where you get your info but I've been an active member on PSW forums for more then two years and I don't recall seeing such failure rate.
The amps were run off of a 150 KW generator, my son is an engineer and this was a LASER show where the power has to be extremely stable. He was anal about verifying sine wave stability and voltage output.
I'm not gonna sit here and argue with you I'm telling you the I tech ones were plagued with problems...period.
My conclusions from this are:
1. Older series i-Techs newer then 2008 and the newer i-Tech HDs are as reliable as the best in the industry.
2. Never use new gear untested by others.
Sorry to hear you went through such a bad experience.
I assume i-techs are manufactured in China. I wonder if the failures pre 2008 coincided with the move to Chinese manufacturing and bugs needed to be worked out of the system. Ask Mackie about bugs.......
Mackie is a great company as well despite it's share of bugs.
