Subharmonic Synth Setting (S3)
Gentlemen, I have to do a rock and roll show for about 34,000 kids from a local deaf school. I have two Radio Shack Minimus 7 speakers and an ADCOM amp. I'll probably mix the bands on a Phonic 6 input board and have Drawmer, Aphex, Empirical Labs and Lexicon processing. I'm hoping my Neve 1073 channel strips will save me.
Now, what subharmonic synthesizer settings should I use to rock the house?
Mikey :shock:
Mikey :shock:
You'd better pick up a 2nd pair of Minimus 7 and run then to the back of the room. Sounds like a great show.
I'm using a 3 day delay time on my DriveRack. That way, no one will have to hear anything until I've had a chance to edit it all in my garage!
I'll post the results.
Rock on!
Mikey
Mr. Dra...he GOTCHA
Ok, Well, Mikey... I think you might have better luck using a pair of Blose 601 series 2022...I would highly recommend at least one Acoustimas sub powered by a belchfire 6000 amp...Remember you need to drive a ground rod through the pavilion floor to at least 10' 3" (and 30.0158 thousandths of and inch EXACTLY) or all life within a 3 mile radius will be baked to cinders the moment the amp is turned on...
***Note*** set the xover frequency to 2K on the sub, making sure to overlap the crossover point by at least 1,950hz Also the sub harmonic synth should be set to max frequency response to make sure there is nothing intelligible in the outputs. Remember these are deaf people that can't hear anything anyway..
So have fun and make sure NOT to wear any hearing protection, you have no business doing sound anyway..
Sincerely, your crabby host
Gspot...
Learning SOOO much here! Thanks to all!
Mikey
Oh no he didn't!
Mik....er....Mickey
Baha! They do hold racks together pretty well...... is there anything on the inside of those besides the jacks?
Nothing useful. There are a few parts and it does change the sound, but is it really for the better? Oddly, a transfer function that I did a few hundred years ago showed nothing. Are we measuring the wrong thing or in the wrong way?
I have so many stoopid questions.
Mikey
