Using DRPA+Bill Fitzmaurice Omnitop 15 tops and Titan 48 sub
KTOKTO
Hello,
I am thinking of moving away from our currently setup to a DRPA+ and have a fre questions on the ease of setup considering I am using some custom built cabinets.
I am curently running two Bill Fitzmaurice Omnitop 15 tops and one Bill Fitzmaurice Titan 48 for our sub. More info on the cabinets here...
omnitops
http://billfitzmaurice.info/OmniTop15.html
titan48 sub
http://billfitzmaurice.info/T48.html
I am a rookie with live sound so the videos I see on the setup wizards on the DRPA+ look very appealing to me. My question is this, how much trouble am I going to have tuning my bands setup with my oddball speakers. I also use a behringer ep amp for the tops with isn't on the DRPA+ amp list.
Can someone point me to some resources that would help me configure the PA+ for my setup?
Thanks!
omnitops
titan48 sub
Thanks!
Thanks again.
The good thing is there are all the tools necessary for you to tame those speakers, you'll probably need a little help from us though. Are you using the Piezo tweeters or the horn loaded ones or the dual horns, and in any case we'll need to know exactly what drivers are in use.
In the meantime you might want to do some reading in the FAQ section:
viewforum.php?f=60
and familiarize yourself with the Start here thread:
viewforum.php?f=61
Hopefully you have the measurement mic?
To answer your questions, I am using the 20 piezo melded array and 15" Eminence Delta 15 drivers in the Omnitops and a 15" Eminence Kappalite 3015LF in the Titan Sub. I do have a Behringer ECM8000 measurement mic.
The tops are being powered by a behringer EP2000 amp and the sub is powered by a QSC GX3.
I currently manually RTA the system using true RTA with hit or miss results. The speakers sound like they have great potential, I just need help so we sound good at more than one in three shows
Thanks again. Please let me know if you need any more information I can round up the specs on the drivers and amps, I just need to know what I will need.
The piezos are Goldwood model 1016 from parts express
http://www.parts-express.com/pe/showdet ... ood%201016
with the housing cut to place 2 piezos side by side at a 90 degree angle and in a stack of 10 pairs high like this.
I think (no, I KNOW) you would get much BETTER results running the tops bi-amped, but thats not what you asked about, and the driverack will help you a LOT in the form you are using now.
There is still the measurement process to determine what the tweeters are capable of, and then the selection of the crossover type, and slope, and implementation...that same process between the subs and low mids...plus an HPF to protect the subs and low mid and even the tweeters. even though they don't present a dynamic load...
These are all things that are not covered in the manual or the setups, but are in the reading. So, if you want to learn, proceed..
I didnt realize the questions about the tweeter array were in regards to bi amping the tops.
Id have no problem rewiring the tops and bi-amping them if i would get far better performance.
I will get the recommdedxover frequency later today.
From what I gather, the answer is no but you will get more sensitivity with one. Here is the verbiage from the plans regarding the high pass filter.
"This filter has a 2kHz corner frequency, reducing power to the piezos by 12dB at 1kHz, while increasing their sensitivity from 2.5kHz to 5kHz by about 2dB."
I am only going to be using these tops in bars with crowds up to 350. I'm not sure if I am going to see any huge benefits running these bi-amped for the levels I will be pushing. I am sure that is a question I could post on the BFM forum.
The things of interest to you are the how to's of Auto EQ, alignment, and gain structure. You will probably need to do a alignment based on the physical dimensions of d the disparity. Looks to be about a foot or so? If you have an amp for the tweeters (wouldn't have to be much... probably about 50-100 watts @ 8 ohms? would be plenty, remember the piezo's don't present a resistive load, but are instead reactive..
I think the first thing I would do is separate the array (leave them in the enclosure but run them separate form the woofer and get a snapshot of their performance with no crossover .. in stand alone mode, and post that here.
