Question before buying.
I am thinking of buying a DriveRack PA+ to run my bands PA.
We have two 3-Way Cabs that can be Tri-Amped and two 2x18 subs. Would the DriveRack PA+ work with this or how should I configure this system? Would it sound as good to run the 3-Ways in full range instead of Tri-Amped? Also would I run the monitors through this or just leave them the way they are through my board, we are daisy chaining the three powered 2x10’s on the front on Aux1 and then the 1x15 for the drummer on Aux2. The board is a Peavy FX 24. This board has a stereo L and R or Dual Mono or Mono/Sub.
http://www.peavey.com/products/proaudio ... ade%3B.cfm
Here are most of the specs on what I have.
Carvin TRX153N 3 Way Cabs, want to Tri-Amp
http://www.carvinguitars.com/products/TRX153N
System Type: 15-inch 3-Way, bass-reflex
Frequency Response (-10dB): 50 Hz - 20 kHz
Frequency Response (-3dB): 60 Hz - 18 kHz
Coverage Pattern: 60H x 40V
Crossover: 3-Way with Speaker Guardâ„¢ HF protection
Crossover Frequency: 500, 2.5 k Hz
Power: 600w Continuous / 1200w Program / 2400w Peak
Recommended Amplifier Power: 800 - 1600w
Sensitivity (1w @ 1m): 100dB
Maximum SPL: 128dB
LF Driver: 15-inch Neodymium 3-inch VC
MF Driver: 8-inch Neodymium 1.75-inch VC
HF Driver: 1-inch exit Neodymium 1.75-inch VC
Nominal Impedance full range: 8 ohms
Tri-amp LF: 8 ohms 600w / 1200w / 2400w
Tri-amp MF: 8 ohms 200w / 400w / 800w
Tri-amp HF: 8 ohms 60w / 120w / 240w
Carvin TRX218N Subs
http://www.carvinguitars.com/products/TRX218N
System Type: Dual 18-inch Sub, Bass-Reflex
Frequency Response (-10dB): 24 Hz - 2K Hz
Frequency Response (-3dB): 30 Hz - 1.5K Hz
Coverage Pattern: Omni
Crossover: None
Crossover Frequency: Recommended 90-150 Hz
Power: 1600w Continuous / 3200w Program / 6400w Peak
Recommended Amplifier Power: 2000 - 3200w
Sensitivity (1w @ 1m): 102dB
Maximum SPL: 134dB
LF Driver: Dual 18-inch Neodymium 4-inch VC
Nominal Impedance Full Range: 4 ohms
Amps
2 Carvin DCM200L for the subs
http://www.carvinguitars.com/products/DCM2000L
OUTPUT POWER
1 CHANNEL RMS continuous
- 8 ohms: 400 watts
- 4 ohms: 700 watts
- 2 ohms: 1150 watts
BOTH CH RMS continuous
- 8 ohms: 325/325 watts
- 4 ohms: 600/600 watts
- 2 ohms: 1000/1000 watts
BRIDGED RMS continuous
- 8 ohms bridged: 1200 watts
- 4 ohms bridged: 2000 watts
- Frequency Response: +-.5 dB 20 Hz - 20 kHz
- THD< 0.03% @ 50% output, <.1% 20-20 kHz @ 90% output
- Output Topology: CLASS A/B
- Power Supply: Switchmode - 60% reserve - see kick drum test
- Damping Factor: >500
- Slew Rate: bridged mode >50v/µs
- Sensitivity (@ 4Ω): 1.0 Vrms
- Signal to Noise Ratio: Greater than 106 dB
- Input Impedance: >20K ohm balanced
- Speaker Guardâ„¢ DC protection for drivers
- Soft-start power-ups: prevents AC breakers from tripping
- Over-Current: protected
- Under-Voltage: protected
- Thermal: protected
- Fan: variable speed
- Shock-proof SMT construction
- FR4 fire retardant circuit boards
1 Crown XLS 402
http://www.crownaudio.com/amp_htm/xls.htm
2 other Carver amps I do not know the specs right now.
Three 2x10 Kustom powered Monitors
http://www.musiciansfriend.com/pro-audi ... 2000000000
KPC210MP Dual 10" Powered Monitor Speaker Specifications:
• RMS OUTPUT: 100W
• Speakers: 10" Special Design
• Horn: Piezo Driver
• Input: XLR Balanced / 1/4" Balanced, Unbalanced
• Line out: 1/4" Balanced, Unbalanced
• Frequency Response: 100Hz-20kHz
• Input Sensitivity: 1 VRMS
• Sensitivity: 94dB 1W/1M
• Crossover frequency: N/A
• Dimensions: 14"W x 30.7"H x 9.5"D
• Dimensions (mm): 356W x 780H x 241D
• Weight: 36.4 lb.; 16.5kg
One Kustom 1x15 powered monitor
http://www.musiciansfriend.com/pro-audi ... or-speaker
• RMS OUTPUT: 100W
• Speaker: 15" Special Design
• Frequency Response: 45Hz–20Khz
• Sensitivity: 97dB 1W/1M
• Dimensions: 19"W x 24"H x 14.6"D
• Dimensions (mm): 483W x 610H x 370D
• Weight: 45.2lb.; 20.5kg
Maximum SPL: 128dB
Carvin TRX218N Subs
Crossover: None
Maximum SPL: 134dB
Amps
OUTPUT POWER
- 8 ohms: 400 watts
- 4 ohms: 700 watts
1 Crown XLS 402
• RMS OUTPUT: 100W
• RMS OUTPUT: 100W
However, the DRPA+ won't do 4 way...The DR260 will though.
So will it be better to run the monitors through it too?
From looking at the speaker specs, will I have any trouble setting them up? I'll start reading all the tutorials. Just use custom settings and program them in. The crown amp should be in there from what I read.
You will need to run Mono 4 way for FOH and you'll have one monitor mix.
I am using a DR240 (discontinued), and a DRPA (discontinued) to run 4 bi-amp monitors at my primary venue and I have a 4800 running 4 bi-amp monitors on my large rig...
Here's the 121.7 article:
viewtopic.php?f=60&t=2410
Here's a good start thread:
viewforum.php?f=61
and when you get the 260 we'll get you hooked up.
I found another post that was pretty much using the same speaker setup as me. I had to put custom on all of the amps except one. I'll have to read up on how to set the custom amp settings somewhere.
Thanks for the info.
I have ordered the Carvin cabs and subs but they havnt shipped yet. What would you suggest for a 4 way system. I just liked the idea of the 8 line speakon cables. I'm hoping I can link the cabs to the subs using the through jack and then just have one cable from each stack going into the amp rack.
You'll need to go ahead an get the 8-pin panel jacks (and panel) and start wiring your amp rack. Draw out a detailed wiring layout for the rack and the connector. Color code and label the drawing and the amps (front and back) and USE it, then put it in a zip-lock bag and tape inside the amp rack.
Check, re-check, and double check the wiring. There are a lot of opportunities to fry your horns: Routing in the 260, connections at the 260, input connections at the amps, and output connections.
PS - you'll love the 260
Yes it's nice to have only one cable going to the speakers but the 8 conductor stuff is HEAVY!!! and not cheap. Write yourself a program for the 260 and send it to me in an email and I'll peruse it and make sure you got it right...here is a link to the process:
viewtopic.php?f=60&t=2219
I like to put about 1.5 secs of delay on the drummers monitor.
Right now here is our setup.
This is per side.
High mids - 1x12 fender with horn
Low mids - 2x12 fender with horn
Lows - 2x15 Kustoms with horns removed
Subs - 2x15 Kustoms with horns removed
Highs - 2 Horns from the Kustoms
Going to Sonic Maximizer then to 5 way mono crossover
I am hoping that making this setup smaller but adding the 18's will make it sound better. Will I just need to get rid of the sonic maximizer then?
For the subs, I'd rather see a DCM 4000 or better being as how the speakers are rated 1600/3200/6400 watts, meaning program power should be about 3200 watts. At 2000 watts you are feeding each woofer with only 1000 watts... probably not enough to get pumping to good for live sound reinforcement...
Not bashing what you have, just providing options.
