Xover
Just bought a SRX728S. Been using 2 SP118 Peavey. Top cab's are JRX115. Sub amp CTS3000. High amp XLS802. I need the best Xover points for this little system using a Driverack-PA+. This will only be used in the bar rooms.
Therefore, with limited power I recommend crossover @ 118hz LR24 for the sub to the tops and an HPF for the subs of 40hz BW18.
