Trouble setting up dbx driverack pa
djjrocdjjroc Posts: 2
I have 2 peavey sp 2's crown xls 2500 2 yorkville ls 128's crown xls 5000 I have gone through the wizard subs sound terrible i need help :|
  • DraDra Posts: 3,777
    Did you also do the Auto EQ? How and where did you do it?
    What parameters (settings) did it set up for you? Be specific.
  • twintentwinten Posts: 50
    If you will look at your xover you will see that the output on your subs have been turned down by the Auto EQ function. Manually return it to zero or what ever volumn you want. :evil:
  • Try auto level in setup, also in the EQ and crossover sections you can manually turn up or down the gain for Lows, Mids, or Highs.
    If that doesn't work try placing the RTA Mic somewhere else
    I think he hit and ran. Long gone. :roll:
