Need help setting up Cerwin Vega subwoofers
DJCarloz94DJCarloz94 Posts: 4
edited May 2012 in PA General Discussion
So yeah I got a new DriveRack PA+ and when I set up the subwoofers I can't find them in the list :( I went to the Cerwin Vega section and they have the earthquake subwoofers except the AB-36C model, so what now? I use a Crown XTI 4002 bridge at 3200 watts @ 4 ohms for both subs, getting around 1600 watts a piece,
Performance Data: Frequency Response: -3db 40 Hz - 310 Hz / -10db 33 Hz - 350 Hz Power Capacity:
800W RMS / 1600W Program / 3200W Peak
Recommended Power: 1200 w - 1600 w @ 8 ohms Input Connectors:¼â€? Phono, Speakon Sensitivity (1w/1m): 108 dB Nominal Impedance: 8 ohms Maximum SPL: 140 dB
So can someone help me please? I am a noob lol
  • GadgetGadget Posts: 4,915
    What do you have on top of them?
  • DJCarloz94DJCarloz94 Posts: 4
    JBL MRX 525
    Sorry, how much power for the tops and what is the system used for?
    DJ system
    Crown XTI 4002 stereo mode at 1200 watts 4 ohms each speaker
    Ok, well if you do a proper gain structure you should be ok power wise, I'd go with 100hz LR24 for the cross from tops to subs and set an HPF of 40hz BW18.
