DRPA and Community SLS920 / monitors
I have a Driverack PA that I would like to setup up for subs and SLS920 passive mid high boxes. Does the parametric EQ affect both left and right channel outputs? I'm using the left in and outs for the main speakers and subs, and am using the right channel mid out for monitors. Mains are mono.
I've calibrated my Xover outputs to the power amps and set the limiters. Everything seems to be working as it should, just I'm not sure about the parametric EQ only affecting the left outputs.
viewtopic.php?f=60&t=2228
You don't get separate PEQ's but you DO get separate GEQ's...
Then I did the same for the low output, except I fed +4db @50Hz .
This way my amp level controls are all wide open and can't exceed the maximum operating point.
Does this sound acceptable?
Interesting.....I don't remember the topic of using dummy loads coming up here before. What did you use for that?
This thread will perhaps illuminate a different train of thought:
viewtopic.php?f=60&t=2242
I have seen discussions using 5 gal plastic pails, I think filled with water and coils.
How much heat do you get from the coils you made? Whould you care to share the design and parts list?
The power resistors I made are wound on a triangle shaped soft ceramic pillar used in pottery kilns to hold up the shelves within the kiln. I drilled a hole through each end to put machine screws for the wire terminals. I wound the resistors on the form using 16 guage nichrome wire; I forget how many turns is required to make 4 ohms, perhaps 20 or 25 turns. I just measured a length at 4 ohms, then cut it and wound the length on the form. With a thousand watts RMS it glows red, and at 2000W, it's a bright orange color. I don't run it for long at these powers though, as it's hard on the amp. Very few amps are capable of running this kind of power continuous.
I wouldn't put any load resistors in water, but I have seen some old loads in a can of oil for cooling. Mine work fine in the air.
If you like, I can take some pics tomorrow.
I'm just using the limiters to prevent amp clipping, but if you want to set a cap on the sound level to protect the drivers from exceeding maximum ratings, monitoring the voltage level across the dummy loads will tell you where the limiters need to be set according to the particular speaker specs. That's my thoughts on the subject.
The reason I would prefer to do it this way rather than marking the amp level controls as mentioned in some other posts, is because if somebody moves the controls, they can only reduce the levels at the amps, rather than over driving them and causing damage. Also, it's convenient to be able to just open the controls wide open after powering up the amps and walk away knowing they are set where they should be.
You do realize that the limiters on the DRPA are NOT brick wall but peak stop... and they will overshoot...
