JRX115
What if I installed 2225H drivers in my JRX115's ? I have a set of new recones. From what JBL has on the web the 2225H will go up to 1600hz. That is my horn xover point. I could add more power to these.
If you better consider NOT doing it if you are going to ever run them full range. The wrong woofer in the box is a recipe for disaster. A cabinet is designed around a spec woofer, not the other way around.
You could try it and see... but it might not work...
Remember, the cabinet is designed AROUND the DRIVER.. just any box isn't going to work...
