Driverack PA noise issues
Having a serious electronic garbage signal that has just started. It does not increase with gain, hut is always there...Seems to come and go. It appears to have started at the DB button on rear of unit...removed cover, sprayed some contact cleaner..problem is still there. The sound kind of sounds like a scratching record.
The only thing I did was swap out Sub amp before noticing the sound. Not sure what is going in.All preset tunings still have the noise.
Any ideas????
cabentz
Any ideas????
cabentz
Is it on all outputs? Have you tried another preset?
Write down all your settings, then do a hard reset.
Thanks...
Glad it was something simple.
