DRPA+ Auto EQ with JBL PRX612m's
Strange that when doing the outdoor method of Auto EQ on the PRX612m every freq from around 125z to about 10K came out at +3db except 200hz, 800hz were at +2db and 10khz -4db, with -12 db cut from 12k-20k..
I'm wondering if there is DSP compensation in the cab that already flattens its response?
Ive never seen a speaker be this flat? I expected the levels to be all over the place.
How did it sound afterwards? Can't believe that with a full cut from 12-20khz it sounded worth a crap...
outside on a second story deck. Had the speaker and mic up pretty high to avoid reflections
from the deck. Mic at about 5' high directed and center of speaker grill about 4 feet from front of speaker. Had preset for prx612m/prx618xlf /2x3. The sub was not on/used for the auto eq.
The speakers sound good to me with no EQ's on.
I was only concerned with auto eq in the 125hz-12khz to see what the speaker response looked like to adjust for anything that was way off. I can live with how they sound with no EQ.
Also the bands below 125hz were cut way back (I expected them to be boosted since no sub
was on. I usually ignore the extreme high/low due to using MY DRPA which i read is not very accurate in those areas. THIS system is not mine and is the DRPA+. I assummed it must be better than my older DRPA as the DRPA+ went thru the auto eq very quickly with a high res setting.
My system is a DRPA with a pair PRX415m passives. I have not auto eq'd these yet.
They do sound great to me with no EQ on at all in the DRPA HF side.
If the Boost was on it could cause the frequencies list to be Boosted by the speaker then cut by the driverack. I bet the Monitor selection is just the opposite of the Boost setting.
Nope... that won't work...
Nope again, the MIC is the weak point in the LF and HF region but plenty good enough for "Rock and Roll"!
I assume you were using the flat preset...
You should try it speaker @ about 4~feet high and the mic on the deck on a towel or carpet, mic out about 25 feet if possible.
Looks like there was buildup from some walls and whatnot around the speaker, thus the cut below 125...If the response curve is to be believed the response increases below 125 hz to peak @ 90 hz but then falls off to -5dB @ 60hz and 12-13dB down @ 50hz...with no processing. I see they have NO tone controls to worry about...
I'll do it without sub as I usually PEQ the LF by ear (live sound application so LF is mostly Kick).
Last request.
I did an interesting thing the other day... In the venue, I left the room effect PEQ's (5, 4 on the tops and 1 on the subs ... 12" 2way powered and EV s181 subs)that I know this particular room possesses in place, and then did an auto Eq (DR260)...The results were particularly excellent! I often record the bands I do with the Presonus 16:4:2 capture software, but this time I recorded using a 2 track Presonus USB Pre to my laptop running Soundforge 10...the recording was particularly good, and sounded like the mains did out front (I can mix remotely using an Ipad and walk the venue which is a total GAS!). Since the system is in mono I was able to pan the elements around and the recording blew the band away! I was quite pleased myself... best the system has sounded in 2 years!
For true outdoor Auto Eq you need to have NOTHING near you for a very long distance...like out in a farm field...and no hard surfaces on the ground either...
Makes sense that the bass is reflecting out the back port off the wall. I will review procedures and it should fix all. I'll make sure nothing is behind the cab.
Actually the main/mon switch on the back of the prx is an EQ boost. When on the floor it should be switched to monitor to reduce the bass boost from the floor.
