DriveRack PX settings for Yorkie LS801P & RCF ART312A
skelm
Would like to ask for some help setting up the sub/tops
2 X RCF ART312A
DriveRack PX
1 X yorkville LS801p
The tops are in the preset configs, but the sub is not. Here are the sub's details
Max SPL 140dB Peak (134dB Continuous)
45Hz – 150Hz with Adjustable HF Roll-Off
45Hz – 90Hz Variable Boost Frequency
I have tried all the auto-wizarding. I can get a 1/2 decent sound if after doing that i up the DB's on the yorkie +10 but think I really need a proper setup (currently using the provided yorkie sub setup NOT the LS801p)
Thanks for helping out a newb!
2 X RCF ART312A
DriveRack PX
As far as a x-over point... try 100hz use LR24 on each side Set the subs onboard filter to max (150hz). The sub will have all the adjustments and extreme low end protection, but it will not hurt to add a BW18 @ 30hz to be extra safe. Then play with the "Shape" to get the type low end that you want.
Now, indoor auto eq is pretty useless below about 170 hz...If you want a good flattening of the subs you'll need a place outdoors away from all reflective surfaces. I know they are a bit peaky in performance and you could easily slap a PEQ with a Q of about 3-4 on and roll a cut and boost around on them an see where those are and use the two PEQ's available to deal with those.. I'm betting a cut in the 100 hz area and boost around 70...what are messin with you are standing waves/mode indoors.. Bass waves couple and create super waves.
What is you method of auto eq? I am hoping your not going to tell me mic on a stand.. in between the speaker stacks... :roll:
Thanks!
On the back of the LS801P I have the High Freq Rolloff dial on the back of the sub all the way to the right (highest setting 150hz). I have my shape knob at the 10:00 position. On the DR PX i have set my cross over frequency at around 90Hz - boosted 70 by 6DB & reduced 80Hz by about 4db with a narrow Q. Using the 24db filters for sub crossover and top crossover
Still playing around but this is 100% better than before - I will steer way clear of any further auto-wizarding
