If anybody can help configure the px
i have two subwoofers speakers EAW sb 1000 passive speakers and 4 active tops l acoustics , is it possible to hook passive speakers into the the sub outputs and the l acoustics to the top outputs. if possible how can i do the configuration due to the subs are passive and the tops are active
SB 1000's can go as high as high as 156 hz, and I'm sure the L Acoustic tops can go well below 100 hz, depending on how much power the tops have the crossover point could be any where between 70hz and 120 hz, I would recommend a 100hz LR24 cross...
