New Mixer
mclir9
Howdy,
I plan on possibly upgrading from my present Behringer PMH3000 to an Allen Heath MixWizard3 16:2. Will I need to go through the whole rigorous process again of EQ'ing my SP2 speakers as discussed in the FAQ's using the PEQ?? Fingers crossed, I hope the answers no, that process took me hours last time I did it.
No - If you are talking about getting speakers to a flat response, because the mixer does not even have to be connected for that.
Yes - If you mean to get the sound from each input signal like you want it with the channel eq strip. But that will have nothing to do with DR settings.
If you had to monkey with the DR's GEQ to override the channel strip's eq because they were not adequate, that is another story.
You will love the 316:2. Be sure to download the fx software and get a midi cord. Not only does it allow you to modify parameters on the fly, but it changes the dual channel options.
That's the one I'm talking about. Shwooo!!!!
Imagine walking in, setting down the mixer hooking up a laptop and plugging in the speakers, NO outboard gear, no racks of equipment... your not tied down to the mixer, no snake needed any more...put the mixer on stage and walk around, sit with the people in the audience...virtual sound check available on the laptop, record the show for review later.. sell the recordings to the bands...
To me ... this is the biggest game changer in my years of audio... I cannot even consider doing this with an analog board ever again, it's THAT mind blowing...
I did monitors for a national country recording artist this last weekend and the band was amazed and blown away by the sound I got them. Made me look VERY good!
Just sayin, but no, there is no need to reset the gain structure
You might have to, depending on the output range compared to the meters. Haven't looked at the B'ger's output max in comparison.
If there is a change, then it would be consistant for each x-over gain level or amp setting, whichever you choose.
If you must run the Mixer "that" hot, you don't have enough rig. You could consider applying the compressor to control the input level, but use no gain boost. Just keep the DR out of clipping.
I do not have to do this with the SL 16.4.2, at a much lower price point.
At the metal stage they were doing the same desk and the vocals were horendous. I litteraly was inside the building for about 5 minutes and had to leaves cause the vocals were so bad. :shock:
Why is it that I can get much better vocal quality on the SL 16.4.2 and I do this part time, hoping to turn this into a career?
Its cause the good folks at Presonus rock!!!!
Dont get me wrong I still love analog audio, probably more and more every day that I use digital desks, but I really dont have a choice. Its getting to the point where you have to use digital.
Of coarse there is nothing like screaming "Jesus" with a devilish sounding vocal, but don't get me started on the "adrelalization" of "worship".
The Avid Profile is a widly accepted console. You dont suppose the singer or the soundguy factored into the poor vocal sound? I see a lot of Profiles on tour. I dont see any Presonus SL on tour.
