Compression help
mcevill1mcevill1 Posts: 5
Hi, I am new to sound reinforcement and I just bought a couple of DBX266xs's. I would appreciate if someone would help me with a few tips on compression starting settings for a kick and a vocal. Thanks
  • DraDra Posts: 3,777
    I can't help you out, but have you done a search? It seems that Gadget has done this in a prior post.
  • mcevill1mcevill1 Posts: 5
    I did search but I'm not sure if I searched correctly. I'll try again. Thanks
    search.php
    I typed "266" in the keyword field and got a ton of returns.
  • Threshold is the point at wich it begins compressing, attack is how fast it hits, release is how long it holds. If you have a guy who is very dynamic do a higher ratio and if he is very controlled do a lower ratio. Makeup gain is almost like a volume boost. Use it to makeup the volume you may have lost from compressing
    A good place to start on a kick is say probably around 2:1 and for vocals try starting at 4:1. Hope that helps
  • Thanks for the help. I have had some very good success and I think it is going to help me a lot with what I needed it for.
  • dbx has a great white paper about compression that may help as well:
    ftp://ftp.dbxpro.com/pub/PDFs/WhitePape ... %20101.pdf
    jthunderbass's ratios are spot on as a starting point.
    C
  • Thanks Cory. That link was spot on
  • Excellent...glad it helped.
  • GadgetGadget Posts: 4,915
    Hey Coop! Hows things? :mrgreen:
  • Pretty good G...just hanging around this summer. I think I watched ALL of the Olympics!
    How's things with you?
