Connecting pa+ with powered mixer (specifics)
I was reading some responses to other threads and it somewhat applies to what I want to do
with my setup, so I figured I would ask.here is what I have:
Behringer pmp6000 (powered mixer)
2 jbl JRX115's
Now I recently purchased:
18 in seismic audio powered sub
Dbx pa+
I want to be able to send just my highs and mids to the jbl's and just my
lows to the sub, but I don't know if this is possible because I have a
powered mixer and I am not completely sure how to insert the dbx between
the amp and the mixer when it is all together. It was mentioned in another thread about converting the
balanced xlr to 1/4 in. And I was not sure what was meant by
converting...do you just mean get a cable the is xlr to 1/4?... I know I
sound stupid, but it seems like you guys are the people that can help me get this
setup the right way. I was also reading my pmp user manual and i think i can go through the power amp connectors with a trs cable, but i don't know if i need a y cable or when that has 2 trs on each end.I appreciate any help you can provide. Thank you in advance
2 jbl JRX115's
Dbx pa+
As Gadget said, you have to have those to connection points (post main fader / pre amp output, and a pre amp input) Sometimes called "power amp out" and "power amp in".
Check out items 58-61 in the manual. I didn't have time to study it too hard. But that is a start.
The idea is to get through the processing section and allow an inserted device before the power amp stage...
http://www.audiopile.net/products/Patch ... heet.shtml
The OUTPUT has to go to the female XLR for the DR.
I may have seemed snobbish in my 1st reply about firing whoever recommended your equipment. That was not a shot a B'ger or anything else, but for the fact that they recommended gear that you didn't know how to, or even if it would be able to be hooked up.
