using system for djing. Need help how to connect
blindbabyblindbaby Posts: 10
edited July 2012 in PA General Discussion
I just purchased the driverack pa +. I want to connect this to a numark ns6 and a qsc gx7 with 2 pv 118 and 2 pr10. How do I connect all this togather correctly? This system will be used for DJing. Thanks
  • GadgetGadget Posts: 4,915
    Numark>drpa+> gx7... the only option you leave open with this setup is from the ns6 to the left DRPA+ input to the left high out of the DRPA+ to the left channel of the GX7 driving both PR10 in parallel mono, and the right input of thens6 to the right input DRPA+ to the right low output to the GX7 driving both subs in parallel mono...
    set up a 2X4 in the DRPA...
