recommendation for dj settings
blindbaby
Just like alot of others; I am very new in setting up my pa properly. I have a qsc gx7, a drpa+,2 pv pr10 for tops an 2 pv 118 for subs. I would very much like some recommendation for settings on my drpa+. Could you help me out? Thanks
The rest:
As before in the wizard set up a stereo tops stereo subs all custom speakers and amps...
Load the setup
press the xover button, set the subs HPF (the L out) @55hz BW18
set the Subs HPF @ 150hz LR24 (or as close as you can get)
move to the High outs (H) set the HPF @ 150hz LR24
Do the auto eq... you'll need to read about Auto EQ in the FAQ section and gain structure in the "start Here" thread
