driverack settings
I have 2 Behringer B1500D Pro Eurolive Powered Subwoofer and 2 samson auro d15,what should my driverack settings be,i have a driverack pa
Before you vault forward, let us indicate that covering the same area with 2 or more HF deices in a given area... causes all manor of sonic anomalies...
Set the subs (low) range in the DRPA to:
45hz BW18 - 100hz LR24
Play with the boost freq (don't boost above the x-over frquency)
Set high range to:
100hz LR24
That should work for you.
You can also try a higher x-over, say 120hz or lower, say 90hz, but go with what sounds best. (likely 100hz)
