How to Connect without subs
hfc7713
I run my PA from DRPA to amp 1 (horns) and amp 2 (mids) - SRX715 bi-amped.
amp 3 - SRX718.
If wanted to leave the subs at home for a very small venue, I would use a user program I already set up on the DRPA for that purpose deleting the subs and then would I use amp1 for horns and amp 3 for mids? Would this make the outputs hi and low in the DRPA the correct outs to use? If the mid output from the DRPA is left plugged in to amp2 but of course not used (because amp 2 would not be in use), would that be OK?
I just wanted to make sure I have it right.....
Thanks guys.............
amp 3 - SRX718.
If the amp is not capable, there are many ways to get where you want to go, but each has potential for error (some less than others).
