Quick DRPA+ peavey question
Kevrock25
My system.
Yamaha mg16/4cx mixer
Driverack pa+
2-pv15 mains
2-pv118 subs
1-qsc gx3
1-qsc rmx1450
I've read the quick start guide and kinda understand it I'll be
Installing this Friday at band practice. And advice, crossover, feedback, etc
I should know. We are a heavy metal band. Just wondering what I should
Look out for I've never used a dr before. We have alot of rack gear we are hoping
This will replace. Thanks.
Driverack pa+
2-pv15 mains
2-pv118 subs
1-qsc gx3
1-qsc rmx1450
viewforum.php?f=61
viewforum.php?f=60
As far as eliminating rack gear... if you mean compressors, or anything else that you would insert into a channel, that you would use for your lead singer or for the snare... no, the driverack is a system controller, not a channel controller.
I guess my question is is my gear good enough to get good sound
With the driverack.
And any advice from anyOne who has used the dr with this setup
1) You won't blow up your subs trying to reproduce sounds that they can't (but still move trying to).
2) Eliminating the frequencies that #1 accomplishes, you gain available power reserves for the sounds that you will be making. In other words... you can get louder.
Just looked at the specs for this sub. Set the HPF to 45hz BW18 (might even want to go to 50hz)
